Old 02-14-2017, 12:55 PM   #1
Anker
You say you have a light dimming issue. If that's the case you either have a bad battery or an alternator or voltage regulator issue. Have you checked the voltage off the battery terminals when shut off and when idling/running. The first needs to be around 12.5V and the second in excess of 14V.
If power is low all kinds of weird symptoms will arise.
1941 Dodge Luxury Liner Coupe
