Old 02-13-2017, 03:24 AM   #2
edc
550 Anniversary
edc's Avatar
EU 986 cars only have 2 catalytic converters. The headers are straight. They don't have a SAI. One idea might be to flash the ECU with a EU/ROW file. But that won't work with no cats. The ECU gets lambda signals from before and after the cats. So 2 cats and 4 lambdas.
Maybe someone can reprogram the ECU so it does work without cats. But you'll need at least 2 lambdas to run the engine management correctly. And the adaption has to be done to each engine / ECU software version specific.
Optional it might be possible to manipulate 2 of 4 lambda inputs. Lambdas seam not to be can bus controlled, which makes it simpler.
Regards, Markus
My UK car has had a single pair of 100 cell cats. I've tried the lambda spacers and they don't work long-term. I'm told you can get the secondary lambdas mapped out.
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
