Old 02-12-2017, 12:44 PM   #20
geraintthomas
geraintthomas's Avatar
Originally Posted by PaulE View Post
2003 and 2004 Boxsters have the M.O.S.T. (is the least) fiber optic bus for the stereo. I don't know what that means, I just know my 2003 has it and I believe there is more re-wiring to replace the head unit. It has been done though. Crutchfield stereo may have some good info on their website.
Basically, you've got a M.O.S.T. system (fibre optic setup) rather than a conventional setup, which doesn't allow retrofitting of normal stereos as the wiring is completely different. Normal wiring adapters won't work either due to the wiring being fibre optic.
You've got a few choices:
All new setup:
One of them is to rip out the amp, speakers and head unit, and replace them all with aftermarket kit. New speakers, connected to a new amp, connected to a new headunit. It's basically a full overhaul but it'll be completely doable. Speakers have come on since the Bose system in the Boxster. This would require quite a bit of work.
Adapter (very expensive)
I've heard that here is a company called NavTV that makes an adapter for the Bose setup so that you can plug in your new headunit and it'll be plug and play with your existing amp and speakers, but it's something silly like $700. It sucks, but it's a unique piece of kit that was developed to work between fibre optic and copper wires, so it's not your average wire adapter - it's quite a complicated bit of kit, but it does allow you to plug in your old connections and plug in your new head unit, albeit for a huge price. This is the easier option.
AUX Input
If you have anything other than the CDR23 unit, just plug an AUX adapter into the back of it for very cheap from Ebay. It plugs into the CD changer port in the back of the radio so at least you can play your own music. If I had the Bose system, that would be my choice as I wouldn't spend $700 on an adapter, and I sure as hell wouldn't spend days ripping out an original Bose system. Yes speakers have improved since, but it's a good selling point to the car in the future and a real nice originality part. This is the easiest and cheapest option, but you wouldn't get a touch screen.
Sorry to put a downer on it, but there's your options
Porsche Boxster S Type 986
Bi-xenon Headlight Upgrade | 987 S 18" Anthracite Alloys | Android Head Unit | 5000k 55w HID's | 5000k Cree DRL's | 5000k Cree number plate lights | Cree LED Indicators | One-touch roof operation | Bypass exhaust pipes | Parking sensors | Ambient footwell lighting
geraintthomas is offline   Reply With Quote
