Thread: Brake Rotors
Old 02-09-2017, 08:22 AM   #8
WorkInProgressK
A quick way to check is to see if there is a rotor lip at the top. A 1mm lip on the side you can see probably means 1mm on the back side, that is 2mm of wear which is the wear limit for the 986 rotors.
The first time I checked mine way back they were waaaay past that, I think almost 4mm of wear. They still looked good and I had even done my first track day with them (and I was pretty aggravated at the shop that I paid to do the pre-track inspection for not catching that)
This is the real method to check. Usually done with micrometer. Calipers will measure the lip by mistake. Or if you have any visible cracks, they are done.
2001 Boxster S (SOLD)
1991 Nissan Silvia "K"(Forgotten somewhere in Canada)
1989 240sx (Track car)
1987 325IS (Soon to be Spec E30 racecar)
2001 GSXR-600 (Almost warm outside!)
WorkInProgressK is offline   Reply With Quote
