Old 02-08-2017, 11:52 AM   #2
WorkInProgressK
Originally Posted by brybart View Post
I am considering installing the "sport" rubber bushings by elephant vs total replacement of the rear LCA (with OEM LCA) in my 2001 Boxster S. Since I am only planning on the rear, will the stiffer bushing drastically change the handling? Will it induce more over-steer? Has anyone upgraded to the elephant bushings at the rear only and what is your feedback?
You have to consider it as a whole. Do you have stiffer suspension? Heavy sway-bars?
Personally, I don't like sport bushings or stiffer bushing in moving parts(Spherical bushings are a different category). What will happen is that with a harder rubber, the bushing will induce a larger amount of spring rate to the system. Currently with the bushings on the car, the suspension is able to move around during its travel adding a minimal amount of spring rate. If you replace with something stiffer, the overall effect would be similar to replacing the springs on the rear. How much more tail happy it will be? I can't tell you. You can measure how much force it takes to move it through its range before and after.
2001 Boxster S (SOLD)
1991 Nissan Silvia "K"(Forgotten somewhere in Canada)
1989 240sx (Track car)
1987 325IS (Soon to be Spec E30 racecar)
2001 GSXR-600 (Almost warm outside!)
WorkInProgressK is offline   Reply With Quote
