Old 02-06-2017, 11:37 PM   #6
evan9eleven
2004 Boxster S
evan9eleven's Avatar
If you have a bad brakelight or Cruise control activated dash bulb the CC will not work.
Ok, I know that a bad brake light switch or clutch switch will cause the coding to fail, and I checked mine with a voltmeter and they seem to be fine. All brake lights operational.
Are you also saying that if the dash bulb is bad the cruise won't work? I have a 2004, so belive this is an LED, someone correct me if I'm wrong.
@Prirate50, thanks, I'll check in Durametric!
evan9eleven is offline   Reply With Quote
