Old 02-06-2017, 12:14 PM   #1
The Radium King
The Radium King's Avatar
i have 45mm and am running 7mm spacers no problem. 10mm wouldnt be an issue either, but would have to have a look to see if there is enough thread for 15mm. realise that if you wanted to run a narrowbody wheel from a 911 (lots more selection, but with a 65mm offset) you would be looking at a 20 mm spacer. with a 20mm spacer you would want the type w integral lugs, and with 60 mm lugs on the car they wouldnt fit behind the wheel if that makes sense.
