Old 02-06-2017, 02:38 AM   #5
evan9eleven
2004 Boxster S
evan9eleven's Avatar
The only thing that would prevent activation is an incorrect connection on how the stalk & wiring was installed. If you are absolutely positive it is all correctly wired, it should be a simple process to activate it.
So its been a long time since I started this thread, and I want to get back into the project and get the cruise coded.
Since my last post I disassembled the cluster again and double checked all my wiring. Its done exactly as in Wayne's book. I also checked with my voltmeter to make sure that things were in the right place, and that I get 12V when the stalk switch is activated. Everything checks out based on the info I have available...
As I mentioned above, Durametric Pro shows the cruise turned on in the DME, but I can't get the cluster to code. The dash LED does not light on lamp-check when the ignition is first turned on either.
Maybe someone can post the wiring diagram for a 2004 box S, so I can triple check? I'm really stuck and need some help please.
evan9eleven is offline   Reply With Quote
