Thread: Satelite Radio
Old 01-28-2017, 08:03 AM   #5
Lew
So Blessed!
Lew's Avatar
Thanks Achillies for the site on mounting the Antenna, but I have already mounted it. Take a look at the picture where you can see how I planned on installing. I was able to place the small Antenna near the corner of the windshield on the drivers side, and route the wiring under the trim and tuck it under the rubber door seal. It worked out great routing the wire under the lower part of the dash and over to the opening where the CD caddy is located. Since I don't use the CD Caddie I decided to remove it. I might add I am holding the Antenna in place with a quarter size piece of velcro. I plan on cutting a piece of plexi glass I have that will face off the Caddy opening. The Radio will be attached to the Plexi Glass with screws that came with the Radio. Should work out great.....
Artic Silver Boxster S - Black Leather - Black Top - Convience Plus Package
Lew is offline   Reply With Quote
