Old 01-28-2017, 07:15 AM   #16
Miles1
Here is another alternative. Not for a phone but can be modified to work. I was looking for a way to mount my Bluetooth Transmitter. I could have used the power outlet/cigarette lighter but it was battery powered and it wasn't very secure. I wanted an ignition power so I wouldn't have to remove the transmitter with the car not running.
I purchased a power outlet and wired it to the phone connector which is ignition powered. I was debating whether to mount the power outlet in the side panel but that involved drilling. I was looking for a less intrusive method being once drilled, the only reversal is purchasing the side panel. I happened to find this lying around the house. It is a bookend bracket.
This bracket just happened to fit/slide in between the upper console and dash. It was sturdy and secure and removable.
I just bent the bracket to fit and zipped tied the power outlet to the bracket. Kinda hacked but works and looks good from the front.
Miles1 is offline   Reply With Quote
