Thread: Stupid Question
Old 01-26-2017, 08:56 AM   #2
grc0456
2003 Base 5-speed
grc0456's Avatar
Originally Posted by BirdDog View Post
I don't believe you can purchase just the 4th stalk.
Pretty sure the existing DIY's (like the Pelican article) will tell you that you have to pull the airbag and steering wheel (including the clockspring assy) and swap out your existing 3-stalk switch with a 4-stalk switch. But there is another way - See below...
In my case I bought a 4-stalk off of ebay, and removed the 4th stalk (just 2 small bolts) and bolted it up to my existing 3-stalk. Then I sold what had become a 3-stalk switch on ebay (as a 3-stalk switch).
But you CAN install that 4th stalk without pulling the steering wheel or airbag. You need to remove the top and bottom steering column covers. To do that, you'll need to remove 4 screws that hold the covers together and 4 additional screws that hold the front cover (behind the steering wheel) to the top and bottom covers. To get to the screws behind the steering wheel you'll need to turn the wheel to a 45 degree angle (which means you'll need to remove those screws before disconnecting the battery). Once all 8 screws have been removed (4 on bottom, and 4 behind steering wheel) you can pry the front cover towards you to release the top and bottom covers. You'll then install the 4th stalk to the turn signal switch using the 2 bolts you removed from the 4-stalk switch you bought. From that point on you can just follow the Pelican DIY article.
For the harness, see forum member PDWIGHT. You can make your own, but his are awesome - they look factory and will cost you less than if you bought the parts and built it yourself. I made my own, but if I had to do it over again I'd definitely get one of his cables.
It will take you about a minute to enable OBC with your Durametric cable once the software has booted.
Once enabled, you'll be able to switch between outside temperature, miles remaining before you have to fill up, miles-per-gallon, and you'll also be able to set the speed at which an alarm sound will go off. It's easy to lose track of how fast you are going in our cars, they feel the same at 85 as they do at 60, and that feature will sound a gong when you exceed your alarm speed setting. It can save you from getting an accidental ticket.
Hope this helps!
Bill
That's perfect, Bill. Thanks.
