Old 01-20-2017, 09:01 AM   #11
Gelbster
Originally Posted by cnavarro View Post
Early driver tools allowed for the bearing to be secured to the driver.
We had a shop have 6 ims retrofits fail. Turns out the same tech did each one and was using an air tool to drive the nut down on the install tool, which damaged the bearing even prior to installation, pre-disposing it to an early failure.
I figured that if one person was stupid enough to do this, there have to be others and promptly redesigned the driver tool to prevent the user from securing the bearing with a nut. Problem solved :-)
If our procedures seem to be borderline paranoid or ocd, there is a reason behind everything we do and require.
Charles - your 17 pages of Instructions are word perfect. I wish all vendors used such Instructions.
When IMSB questions come up I often mention your 17 pages to the guys who say : "slap it in, get 'er done 'n have another beer' .
Most of us are doing an IMSB Retrofit for the first time. It is a daunting task because going back in to remedy a faulty install is awful. That assumes you get that 'opportunity'!
So thank you for taking the time to write it up. It must have been frustrating to try to imagine every conceivable way an Installer could screw up a repair job that is "just procedural" to quote our mutual friend.
