Old 01-20-2017, 03:14 AM   #1
cnavarro
Early driver tools allowed for the bearing to be secured to the driver.
We had a shop have 6 ims retrofits fail. Turns out the same tech did each one and was using an air tool to drive the nut down on the install tool, which damaged the bearing even prior to installation, pre-disposing it to an early failure.
I figured that if one person was stupid enough to do this, there have to be others and promptly redesigned the driver tool to prevent the user from securing the bearing with a nut. Problem solved :-)
If our procedures seem to be borderline paranoid or ocd, there is a reason behind everything we do and require.
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
cnavarro is offline   Reply With Quote
