Old 01-18-2017, 03:44 PM   #3
Gelbster
If I ever do an oil cooler I would probably go with the Mocal thermostatic sandwich plate coupled with a derale scoop cooler (if I can find a spot under there) or else the derale hypercooler with fan pack with possibly a duct to pull cooler air from somewhere, maybe under the car. Keeping the OEM heat exchanger in place. Short lines so hopefully minimal pressure loss. However my oil temp, as measured in the left valve cover, mostly stays between 200 and 220 (at Roebling in the 70's it gets to 210-215 by the end of a 20 minute session) and on tracks that are a lot full throttle (Sebring and the FIRM for me in July) it will get over 220 by the end but not to 240, and I have never been over 240F.
Oil.pressure for me starts to go down (as observed on my videos around 210 or so), if I got a cooler it would be to try and keep my oil closer to 200F to minimize pressure drops during cornering.
I am not trying to talk myself into a (needless-thanks JFP!) project but for sake of an interesting discussion -
Flaps has an interesting proposal .It is an outa da box solution to the lack of space for the cooler.
But if you fit an oil cooler,wouldn't the water cooling system benefit if you removed oil cooling from it's list of tasks ? Surely you wouldn't want to keep the heat exchanger and do an oil cooler? The 2 HeatX delete plates I linked above do not offer that option anyway. And then there is the gearbox oil cooler to find a home for. Maybe Flaps would have both in the existing spoiler side by side?
