Old 01-12-2017, 05:04 PM   #2
PerfectSum
I had to do the same thing. Instead of using the decals adhesive, I taped it on from the inside, but the tape still left foggy areas.
I'd suggest making a small bracket/holder for it that you can set on the rear deck so you don't ruin the vinyl.
I am not sure if this will work on the rear window, I used it for my windshield, but I don't see why it wouldn't work. I went to a fabric store and got a small piece of clear vinyl (exactly like the rear window but thinner), then I attached the decal to the vinyl. Static cling held the vinyl to the window, and I could peel it off whenever I needed too.
Wow, that is really clever. Thank you, I just might have to do that!
PerfectSum is offline   Reply With Quote
