Old 01-10-2017, 06:40 AM   #2
JayG
On the slippery slope
JayG's Avatar
Originally Posted by sudheendrar View Post
Thanks y'all. Going wide - what are the disadvantages?
Would these touch the fender inserts if turned lock to lock?
I suppose since the outside diameter may not change, it will not impact either bump stops or any suspension components? Also, any change in the speedometer reading?
My rims are standard 17" - 7 J X 17 H2 with 55 mm offset up front and 17" - 8.5 J X 17 H2 with 40 mm offset back rear.
Thoughts?
SR
I run 225/45-17 and 255/40-17 without any problems
As far as speedo, well to my knowledge, all of our cars read a few MPH high anyway.
Most 225/45 and 255/40 are the same diameter 255/40 is the factory size so there shouldn't be any speedo change over factory
2004 996 Targa Tip
Instructor - San Diego region
