Old 01-02-2017, 11:04 AM   #2
911monty
911monty's Avatar
Originally Posted by Jojo View Post
Funnily enough, the car started with the CPS disconnected, however it did take some extra cranking, but did not wait till the engine is warmed up to see what the effects are, if any
I think I shall place an order for a new one and see how it goes and will let you know....
Cheers
JJ
You might double check that it was the CPS you disconnected. The CPS is the trigger that tells the DME where the pistons are in relation to TDC in order to fire the spark plug coils. Without it connected the engine will not run.
