Old 12-27-2016, 10:03 AM   #11
911monty
911monty's Avatar
Originally Posted by Coaster View Post
I didn't change anything with the key, just the black latching mechanism with the door handle micro switch. I can't see how the key wouldn't work unless there is some alignment or something I missed. I clipped on the handle stud to the black box but didn't touch the tumbler in any way. Didn't even touch the door handle. The cylinder has tension and returns to the neutral upright position when released. Maybe it never worked, I can't remember a time when I had to use the key to get in.
So you replaced the door latch? I attached a picture of the back side of the handle. You can see the paddle that has to be inserted into its receptacle on the latch mechanism. The Pelican DIY doesn't discuss this. This was either not inserted when you installed the lock mechanism or it is broken.
So did you get the wheel off and hood unlatched?
