Old 12-21-2016, 09:38 AM   #1
rick3000
There Is No Substitute.
rick3000's Avatar
The 986 (Boxster) rear trunk was designed to fit a set of golf clubs, so it will definitely fulfill that requirement. That said, the maintenance on a Porsche will generally cost more than a Miata.
As much as I would like to recommend a Boxster, it sounds like you are looking for whichever car will be less troublesome to own. While the majority of Boxster's only require regular maintenance, when they do require work, it can be expensive. So I would probably suggest a Miata, solely because it will be cheaper to own. But if you don't mind spending the extra money when it is needed, very few cars can match the handling of a Boxster for the price.
