Old 12-20-2016, 02:28 PM   #19
Meir
1999 base
Meir's Avatar
From the picture it’s hard to tell the diameter of the bypass pipe, but if the pipe is 1.5" you can go with the 2" valve and use a reducer. I personally don’t like the electric version of these valves, but it can be done with both.
2.0" Electric Exhaust Cutout Downpipe Kit E-Cut Catback Valve Manual System | eBay
If you look at the link I posted before, the guy shows in detail the hookup of the vacuum system and the electrical portion of the control.
Not too complicated.
I started with 2” -1.75” reducer so the bypass pipe is 1.75, and the valve is 2”.
2” is the smallest valve I could find. I’m currently straggling with the 180 degree U pipe that I will probably have to fabricate, or change the plan and go with 2”-1.5” reducer and 1.5" piping.
You can see more about project here:
General piping question
I still need to work on my fabrication and welding skills so I’m learning.
