Old 12-18-2016, 05:14 PM   #1
Nedlands
The boxes for the alarm ecu and drilling a hole are ok and all that but only address having a puddle in the car rather than avoiding getting one. Personally, I prefer a dry car which doesn't smell fousty and damp.
In addition to replacing my foam trays, I filled the extra space around the rear drains with expanding spray foam, trimmed it back and then sprayed the area under the trays with flex seal to give the poor design the best chance of working. New drip trays, then finished the job. A year later I have no leaks and dry carpets.
To find the source of the leak you need the carpet out. All of it! I then use talcum powder to coat the area and a water source to create a stream on the roof. The water will leave a trail on the talc coated surface which points to the source....
Good luck
Nedlands is offline   Reply With Quote
