Old 12-17-2016, 05:13 AM   #1
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
This is the most reliable car I've owned...
I can't believe I'm saying this, but I think this is the most reliable car I've ever had. 15 years, and 72K miles on it. Ok granted, I don't have that many miles on it for the age of the car, but below are the only things I've ever had to replace on the car. Everything else is still original and working. All the instrumentation and dash bulbs are still working, the HVAC display is still good/A/C still blows strong without having to recharge, CDR 220 radio is still original and works, IMS is original, car has never needed an alignment, as it tracks straight, tires wear normally for the car, and steering wheel perfectly centered, ignition switch/clutch switch still original. Knock on wood big time, as I don't want to jinx myself, but this car has been more reliable than any of my previous and current cars (Audi, BMW, Infiniti, Benz). How can this be? A sports car being reliable?!...anyone else have this experience? At this rate, I'm not sure when I'll be able to replace the car. LOL
Items replaced:
Water pump replaced at 58K (original failed)
Polyrib belt at 50K (as a precaution)
Motor Mount at 58K (original failed)
AOS at 65K (as a precaution)
E-brake switch for top operation at 65K (original failed)
Factory 03 top and frame with glass window (changed in 09 when plastic window of original top ripped)
3-stalk levers for directional indicator/cruise control/wipers (directional cancel/return failed)
Coolant tank (at 40K ish)
Regular maintenance items:
Oil and filter changes every 12K or 2 yrs
Fuel Filter at 58K
Spark plugs at 30K and 60K
Brake pads changed and 1 rotor set as needed
Cabin filter every 15k
