Old 12-14-2016, 09:09 AM   #10
ryanjboutin
POG champ, 1995.
Yeah, I have some of those. They are held in by the frame for the adjustment worm gears. Your frame may be broken, causing it to fall out.
I may have a spare frame, too, but replacing it would require disassembly of the headlight. I can send you the parts of you want to try to fix it. Alternatively, you could send me the headlight and I'll fix it for you.
You could just pop a new bevel gear in, but it may fall back out if the frame is broken.
Would using a simple Krazy glue on the teeth fix it maybe?
...with a new piece, of course.
1999 Boxster 2.5l 5-spd. 168k miles and climbing.
Build: http://986forum.com/forums/show-tell-gallery/63257-greta-not-really-build-so-much-maintenance-record-build-thread-w-bs.html
IG: @ryanjboutin
ryanjboutin is offline   Reply With Quote
