Old 12-12-2016, 07:45 AM   #1
oldskool73
oldskool73's Avatar
Whats this black box inside 996 headlights?
Got a second hand pair of clear headlights from a 996 (Australian, non-litronics). Inside they've got an extra black box that I've not seen in a 986 headlight...
Got 3 wires going in that piggy back of slots on the normal connector. Bit hard to see where they go to, but it seems to be sharing the lowbeam +/- and maybe the fog light +? It also appears to be attached to the arm that adjusts the reflector height at the back.
2 Questions...
1. Any idea what it does? I'm guessing it may drive the arm and adjust the beam height for some reason?
2. Any idea how to remove it so I can get the reflector out. Seems to be pretty well attached to the adjustor arm behind it with no visible way to remove.
Cheers!
oldskool73 is offline   Reply With Quote
