Old 12-10-2016, 10:36 PM   #1
911monty
911monty's Avatar
I have removed mine several times, quite easy. First remove the height adjustment lever by prying straight off the shaft with some non scratch pry tool, a plastic knife works well enough. Then remove the recline lever, it is a ball and socket that pops into it's shaft. Notice there is a plastic rod from the recline switch that must fit back into it's receptacle on the lever. Remove the 2 screws. Now push up from the bottom of the trim plate to release the 2 catches on top then pull away from the seat. The recline switch is attached to the trim plate by 4 latches. Gently pry and the switch will come off. You're on your own for the paint!
