Old 12-09-2016, 08:11 PM   #1
BoomerRoadie
Stereo Aux Conversion
Hi.
Here is another project....I hope you're not getting tired of me. I searched and read a bunch, but did not quite answer this one.
My wire harness plug on the back on my CR-210 looks like this.
That blue one is the plug I want to replace that has my Aux input. The problem is, my harness plug is all one piece. The yellow, green and blue plugs are connected to each other. It seems like they should be able to slide out of each other, but I'm not sure how to do that. Can that be done? Do I just need to use serious force?
Then assuming I can get them apart, will the Aux cable work if I put that one in place of the Changer plug?
Thoughts?
BoomerRoadie is offline   Reply With Quote
