I read up on this before so just going off memory but the 911s have a bit different offset and 11" is too wide for the rear. The turbo 911 is even different yet. I'm running 8x18 fronts with 235s and at full turn you cannot even get half a finger width in the gap to the inner fender. Rears I believe you can go up to 10.5 but with like a 275 tire max. Just going off memory so recheck all this. Check the offset and post that up so people who have something similar can tell you if they made it work. Size is one thing but offset is equally important. If they are factory wheels the offset is right on them. I'm using newer Cayman wheels
