Old 12-06-2016, 06:18 PM   #1
steved0x
steved0x's Avatar
OTC grappler arm plus harbor freight FWD bearing puller kit is probably the cheapest way without using a slide hammer. A slide hammer loaner tool plus a bearing puller loaner tool (if available) would be free. With both of these you (since you said front) would only need to remove the pinch bolt at the top of the front drop link and then slide the wheel carrier down a little, vs removing the tie rod end (can be easy) and the lca ball joint end (can be very hard, especially if it is the original one).
With a used hub, who knows what type of bearing you are getting?
