Thread: Wheel Weights
Old 07-14-2006, 04:22 PM   #1
donv
donv's Avatar
Glad to hear this - thought it might have been the wheel cleaner (P21s)! After a track event (more specifically the clean up after it) I noticed several weights were loose. I'm going to have to find another solution, as I don't have dedicated track wheels and duct tape will look "less polished" than I'd like.
Originally Posted by EPIQTodd
Wheel weights are typically .25g each and are mounted to double sided foam tape. Those who track their cars might notice that on the front wheels the forces and heat move or remove the typical wheel weights. I have to use duct tape over them to keep them from shifting toward the inside of the wheel or coming off altogether.
Any wheel/tire place has these weights, and you don't want to remove them unless you want to shimmy while you drive. If that's your thing, go for it.
2001 Lapis/Black/Black, PSM, Rear Speaker Kit, Optima...
donv is offline   Reply With Quote
