Broken Tranny Mount
Gelbster, Small Block and Particlewave. Thanks for the quick replies and getting the orientation of my photo correct. From the link that Particlewave provided it looks like the exact same break, and I had a CV joint fail on that side. Also had a sagging front engine mount with I fixed with the inserts you can get from Pelican.
I think I'll hunt for a shop that can weld it up before I go for a swap. I've found a couple in the Bay Area that I'll reach out to. I'll update the post when I find a solution.
