Old 11-26-2016, 01:53 PM   #1
xoo00oox
Hello,
what engine type is the 1.8 T 20V? What ECU version do you use?
Regards, Markus
It is the very popular engine used in VW and Audi cars. Five valve per cylinder, very inexpensive, reliable, available,and tunable.
Early version was drive by cable, later ones drive by wire. I used the early AEB 1.8t in mine. It uses a Bosch ME7.5.
Another big advantage is it bolts right up to the transmission with no adapter being that the VW Passat uses the same transmission.
xoo00oox is offline   Reply With Quote
