Old 11-21-2016, 11:29 AM   #1
Meir
1999 base
Meir's Avatar
Not a very complicated project. (Done it 3 times)
You can leave the axels hanging.
The only thing you will need that is "special" is the 10mm triple square, and the clutch alignment tool.
I also got a cheap transmission jack from HF, and engine support bar.
Makes life way easy. The support bar will hold the engine from the top, so you don't have a jack stand in the middle of your way. Also helps you lower the engine a bit, to get better access to the transmission top bolts.
