Old 11-21-2016, 05:42 AM   #1
Need_for_speed
Originally Posted by geraintthomas View Post
Sounds like what I'm having. When you say bend with a screwdriver, which way are you bending? And which ends, the female or male?
Female end. The connector is a metal clip inside the plastic housing. On mine, the clip had become loose and no longer made a solid connection with the pin in the headlight housing. I was able to bend it back with a small screwdriver.
Need_for_speed is offline   Reply With Quote
