Old 11-17-2016, 04:29 PM   #3
Luv2Box
Luv2Box's Avatar
I had this done for the Big Red brake upgrade and everything went on without using shims. The only issue is the axle rotation sensor does not register the smaller diameter axle and your dash will light up with brake, ABS and seatbelt icons. A bracket will have to be fashioned so the sensor is deeper into the housing to read the rotation or you will have to swap the axles out to the "S" axles. I've been driving mine for four years with a makeshift bracket with no issues.
Luv2Box is offline   Reply With Quote
