Old 11-13-2016, 04:25 PM   #1
morgal48
morgal48's Avatar
As for the gear oil, Porsche has use a unique spec full synthetic lube in their gear boxes. While some have had limited success with aftermarket lubes, we find that many lead to problems including problematic shifting in the cold, while the original product does not. Over the years, we have literally lost count of how many gear oil changes we have had to make for customers that switched to the aftermarket, only to find shifting issues when the weather turned cold. When switched back to the factory lube, the problems disappeared. So while the lube may cost a bit more, it does work.
I bought the Porsche oil based on the posts read here - many from you on the virtues of the special OEM oil. Really was wondering what would cost $15 for 3 liters. Looked, but did not find the LN part at Sunset. Thanks for your input - I've learned a lot here in the past two years from many.
2000 Boxster S
2010 Volvo XC60
2011 GMC Denali HD 6.6L (sold)
2008 Cayenne S (sold)
1989 Targa (sold)
morgal48 is offline   Reply With Quote
