Old 11-11-2016, 07:25 PM   #1
AZ986S
AZ986S's Avatar
Looks good, did you do the caps with a tiny brush?
Yes, I tried a couple different methods that didnt't work, then had to strip the paint off and start over
I finally went to Autozone and found some touch up orange paint with a brush.
Finished with a couple clear coats.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
