Old 11-10-2016, 07:38 AM   #19
BruceH
BruceH's Avatar
Originally Posted by Anker View Post
What I am really interested in knowing is whether the suspension needs to be loaded or unleaded when replacing the arm, and also whether it is possible to replace it without removing the brakes. On the diagrams it looks like it should be possible.
Thanks-Anker
Yes, you need to load the suspension when you install the new arms, the arm will slip right in. No, you don't do anything with the brakes. You will need to remove the underbody panel for access. I ended up replacing those parts with new since mine were pretty chewed up. It is a pretty easy DIY and well worth it! Good luck
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
