Old 11-10-2016, 06:50 AM   #17
steved0x
steved0x's Avatar
Originally Posted by Anker View Post
What I am really interested in knowing is whether the suspension needs to be loaded or unleaded when replacing the arm, and also whether it is possible to replace it without removing the brakes. On the diagrams it looks like it should be possible.
Thanks-Anker
You don't need to remove the brakes to do the rear track arms, or the front equivalents.
You may need to load/unload the suspension for two reasons:
1. To get the monoball end to line up in between where it needs to go so you can put the bolt it.
2. To get the fork end to line up with the LCA so it can slide over the LCA and get to the point where it can be bolted.
Theoretically, you wouldn't need to load/unload the suspension, because when the track arm is mounted, it can accommodate the extremes of the suspension movement, but in practice, it is very hard to get things to line up due to the stiffness of the monoball bushing.
Once you get under there and start fitting it together it is all very intuitive. After you do the first side, the second side will take like 10 minutes
