Old 11-09-2016, 11:37 AM   #2
Meir
1999 base
Meir's Avatar
Originally Posted by geraintthomas View Post
Thank you
My only concern is that I use HID's, and the courtesy light uses a dimming feature to turn itself off. I wonder how that would affect the HID's - I'm hoping they'd just turn off once the voltage goes under a certain amount.
well, the courtesy light will not be connected to the low beam circuit.
it will activate a relay that will switch the lights on and off.
so when the courtesy light will dim out to a certain level (in voltage), the relay will interrupt the lights circuit instantly.
the relay i tested disconnects/reconnects at 3-5 volts range.
here is a quick video i made.
https://youtu.be/mOkvLh2l1fw
pay attantion to the clicking noise coming from the relay, once the lights dimm out at around 3-5 volts
ignor the first click sound that is coming from the power supply.
