Old 11-08-2016, 07:23 AM   #1
redciv1
redciv1's Avatar
Originally Posted by winter.k View Post
The tire sizes match 996 specs, idk if tires for Boxster 18's are the same, or which offset is for 986. But, if these are from a 911 you will need ~20mm spacers on the rear wheels only. I run the same 996 wheels with 20mm spacers in the summer.
Since these are the reps, I do not believe the spacers are needed. +47 sounds right for a 10" wide Boxster rear wheel. Also those tires sizes are Boxster as well.
TO OP:
Would you consider selling rear set only?
redciv1 is offline   Reply With Quote
