Old 11-07-2016, 12:42 PM   #12
jb92563
jb92563's Avatar
Steel bearings withstand 350,000 PSI and you belt may be tensioned to ~30 lbs exerting a pressure of perhaps 1000 lbs on a square inch of bearing.
No, removing the belt wont help the bearings at all.
In fact not having the belt on the engine will prevent you from starting the car up periodically, which is definitely good to help everything get some fresh lubrication throughout the winter.
You are much better off leaving the belt on and running the engine for a while (20+ minutes to allow the oil and radiator to get nice and hot) each month With the garage door wide open and your house door completely shut so you don't succumb to carbon monoxide poisoning.
