Old 11-07-2016, 10:49 AM   #10
911monty
911monty's Avatar
If you find the impeller blades have broken off, try to find all the missing pieces.
One place to look is the oil/water heat exchanger on the top of the engine. The debris will plug it. You will need 2 new "O" rings.The other place to look is in the large hoses near the w/p. If you can not match up and account for all the pieces ,check back with us for more suggestions.
You will need 4 "O" rings. 2 for oil side and 2 for water side. They are different sizes.
