Old 07-12-2006, 07:30 AM   #1
denverpete
Originally Posted by rock88hard
I am not interested in lighting up the tires. That was to help describe my issue for those with enough courtesy to help (which i really appreciate mnboxster and bigislandboxster) It was raining again today and believe it or not, I had to take it back out... back out to get the **************** scared out of myself again (a moth to the flame). So if it is oil maybe it's coming from the car itself?
I am getting a safety inspection tomorrow. When I find out what is going on I will post here to help anyone else who may have this problem. BTW I know it has 200 hp, i said i didn't have an owners manual. I didn't say I was without a brain. But thanks for you smart ass remark anyway pete.
Hmmm. I guess I offended you, if so, I apologise.
You will note however that you mentioned you couldn't "smoke the things". And, you wouldn't be the first new Boxster owner to post here that the car doesn't really have the ability to do burn outs. I was serious, actually, about the Mustang. From experience I can say that the new ones can really light up the tires!
The oil that MN and BIB were referring to is on the highway not from your car. If it hasn't rained in awhile, the oil from the asphalt and other cars can create a bit of a slick when it first rains (prior to getting washed away). This is particularly true if the weather is really hot prior to the rainstorm. Arizona is notorious for this.
As MN and BIB mentioned, you most definately were hydroplaning. Check out Tire Rack online. You can view the differing characteristics of the tires (cornering, road noise, wet weather, longevity) along with reviews (usually not that helpful).
As to the cars that were flying along while you couldn't - again that could be old tires, or simply that the Boxster has much fatter tires than most cars. While this gives you a huge advantage in dry weather, it's most definately a disadvantage in wet weather. The large surface area of the tire actually pushes the water (or snow) in front of it. With a larger area, you have a better chance of "lift off" into hydroplaning. It also makes it more dangerous to turn since water (or snow) can build up on the inside of the tire and cause you to go into a straight skid. Skinny tires are actually much better in the rain and snow.
At the risk of being called a smart ass again (or worse), I will leave you with this bit of advice if you find yourself hydroplaning again: Completely let off the accelerator, do not use the brakes, and try to maintain a straight line. As your speed bleeds, the vehicle will eventually find a speed where it can again channel water under the tires and you will regain control.
I'm glad you're safe....
'06 Cayenne Turbo S, Beige Metallic/Tan
Ex - '99 Arctic Silver, Red Interior, Silver Top
denverpete is offline   Reply With Quote
