Old 11-05-2016, 09:30 AM   #11
Gelbster
Lew,
For the 2000MY both single and double were fitted.Until you separate the transmission from the engine, you can't be sure which you have.You need to measure the 'dish' in the IMSB flange.
If it is an OEM flange, the depth will be 19.27mm if it is a 6204 single row. A 5204 double row flange has almost no dish - almost flat.The LN flanges and other aftermarket(like DOF) have different 'dish' depths.
There are many other things to be concerned about.
Did you see the car I PM'd you about ?
