Old 11-04-2016, 12:54 PM   #23
Gelbster
Originally Posted by Need_for_speed View Post
Very true. And the best OCD enthusiasts you could ever find will sell their loved one via the PCA. If I had it to do all over again, that's where I would go to find a used P-car.
When I was researching, I looked at either a 986 with an IMS I could replace, or a 2009 or later model with no IMS to worry about. Unfortunately, the later models are still selling in the mid 30s...well above my budget.
We followed exactly the same path to M96 ownership !
With hindsight I made many shameful & expensive errors:
1. Using the word "budget" and Porsche in the same sentence is nonsense. I had no clue !
2. Buying a car with 'fresh LN IMS" -disaster because I did not learn about the gotcha phrase "Prequalification Inspection" until after the engine died - a few weeks after purchase!
3.Until you have read all 25+ "Modes of Failure" from Jake Raby , you are clueless
4.Until you have listed all the special tools,equipment and procedures required to rebuild an M96 you do not understand why a rebuild cost well over $8K.
5. Do you have FAA standard of mechanic skills ? -you will need them- read how to check cylinder bores as an example. And if you don't do this all your 8k is wasted.
6.Have you found some competent, honest M96 Indies who you will enjoy working with? You will be seeing them often !! And one of them should do a PPI on a car the other one suggest for you.
People sleepwalk into Porsche ownership blinded by the "Deutchland uber alles mechanical" nonsense.Think Ferrari and you will be closer to reality. Yes, I work on both !
And this afternoon I am re-installing an M96 .Yes, I rebuilt it and it cost way more than $8k diy.
