Old 10-29-2016, 04:35 PM   #4
Smallblock454
Hello Cristian,
maybe helper springs could be a good idea in that case.
I would recommend that the springs are "pre-tensioned", because everything else will get you problems.
If you don't have pre-tension the spring can move in extreme driving conditions. And because your car is a sports car you can have them.
Also you can run into problems when you jack up the car and the spring can move, because the spring has to be in a defined position in the spring holder.
Worst case can be a broken spring or a damaged spring holder.
Regards, Markus
Smallblock454 is online now   Reply With Quote
