Old 10-28-2016, 11:42 PM   #10
alansanmateo
For a non spirited daily driver where road manners and long life are most important, here are my recommendations:
Michelin Pilot SportA/S 3+
Michelin****Pilot Sport A/S 3+ (W- or Y-Speed Rated)
BFG g-force Comp 2 A/S
BFGoodrich****g-Force COMP-2 A/S
Good grip wet dry and even light snow if you go to Tahoe. High treadwear #s so 20,000 miles per set is very realistic. Do spend $120 and have a neutral alignment done to maximize tire life.
20,000 miles will take me 5 years. Maybe more.....
I decided that I didn't need the AS, as there is zero chance this car will see Tahoe
The drive from the Bay Area to Tahoe is lousy, and it wouldn't be much fun in the Boxster.
But I do agree that the Michelin would be a great tire if I there was any real risk it would see snow
re the alignment issue, I had heard that the Boxster is supposed to wear the rear tires on the inside edge - that the camber is part of the engineering. Is that a load of crap? (or am I misunderstanding the alignment comment?)
alansanmateo is offline   Reply With Quote
