Originally Posted by p3230
Mine the courtesy lights don't work the power lock don't work the rear defogger doesn't work and the alarm doesn't work, also the side markers don't work all from water under the drivers seat. I've been trying to figure it out but I'm almost at the point of getting rid of it. So good luck with yours and I'll check here to see how you are doing.
If you had water under the seat, then you already figured it out.
You killed your CLU. Send it to ECUdoctors for repair...cost about $500.
I recall that you had it "repaired", but it was not actually fixed.
Send it to a competent and reputable company, like the one noted above.
