Old 10-24-2016, 12:08 PM   #1
particlewave
Yes, check for voltage at the current distributor and check the positive battery cable connection to the distributor at the firewall for corrosion.
You can have good voltage at the distributor, but still have a bad connection not letting enough current through. Always clean connections.
particlewave is online now   Reply With Quote
