Old 10-18-2016, 12:08 AM   #1
KuaiThunder
Originally Posted by BirdDog View Post
Search the forums for advice on how to check your AOS (Air/Oil Separator).
When those go bad (diaphragm fails) lots of smoke will be produced.
I strongly suggest that you don't drive the car until it's fixed.
I did search the forum and notice AOS failure could cause smoke. I thought fail AOS would only produce smoke in the cold engine start-up. Seems like it could produce lot of smoke constantly if it fail enough. The car is parked in the shop and I will ask them to change the AOS first to see whether the problem will go away.
Thx
KuaiThunder is offline   Reply With Quote
